FZR400 3TJ not firing
Posted: Tue Sep 21, 2010 8:48 pm
hi folks, have had a little check for common problems but thought people may be able to shed some light on my issue:
first race meeting the other day and the bike started first time on the button with choke
needed a bit of throttle the second time (having cooled down an hour or so later) along with choke, but went fairly easily
third time needed a bit more persuading with the throttle, and help to idle until warm
fourth time, nothing... turning over fine, but not even trying to fire
not sure if its related, but mainly out of right handers with a bit of lean, if out of the power band it was spluttering a bit, and popping but running fine once into the power.
on examination after not starting i found a block connector melted under the tank by fuel pump but bypassed that today and still same problem....?
starter motor, and fuel pump both working fine. in the short time i've had it its started first time with choke... it has a race airbox thing under the carbs, so will take them off tomorrow to look at plugs.
any help would be greatly appreciated. are there any common things to fail on these race bikes?
Ta!
pics tomorrow
Ta!
pics tomorrow
