symptoms of dodgy rectifier
EZMOTO
Bike owned: FZR4
Post by EZMOTO » Sat Aug 21, 2010 12:37 pm
my hybrid has been fine lately, i'm using an fzr600 3he engine
but last night after giivng her some in first gear pull away, it seems i have a misfire, it feels like electrical
and when i checked the rectifier its red hot and the wires are red hot as well, which doesnt seem right
could this be my problem, before it ran very clean but now it still revs out ok but doesnt pull away nice and crisp
i know the stock rectifiers are a problem, what would be the problems of a dodgy rectifier
also the 3 white wires that goto the rectifier, does it matter what way round they go as they are all white no colour markings, as i have a spare 600 which doesnt have a plug, so will need to cut and resolder, just wondered if i can wire them up any way round for the white wires
LUCAS
Bike owned: NC29 and NC35
Re: symptoms of dodgy rectifier
Post by LUCAS » Sat Aug 21, 2010 6:52 pm
It doesn't matter which way you wire in the 3 wires from the generator
Post by Evilchicken0 » Sat Aug 21, 2010 7:24 pm
I haven't heard about rectifiers being a problem ... it's not a honda afterall.
The rec do get hot, they soak up the extra charge from the alternator and convert it to heat .... so maybe the alternator is giving the rec a hard time.
Pulling away cleanly might be down to the carbs being out of sinc or the mixture could be off. Better still when did you change the plugs last ???
dobbslc
Post by dobbslc » Mon Aug 23, 2010 9:09 pm
Have you got the rec mounted on a nice piece of metal to dissipate the heat? If it's in a modded bike it could just be bolted to something plastic and getting too hot.
fzrtim
Bike owned: FZR400 FZRhybrid FZR600 RSV1k
Post by fzrtim » Tue Aug 24, 2010 1:11 am
Normally when the rectifiers go, they just burn out. Thats what my 3he did anyway however the 3tj when the rectifier went the battery kept draining overnight (even though it charged the battery when running!)
If you unplug the rectifier it should still run but with a total loss system, should be an easy way to eliminate the rec as a porblem. As you probably know all the rectifier basically does is change the three phase ac voltage from the generator to 12v dc to charge the battery.
Hogdigerdy Dog
Bike owned: FZR400RR 3TJ, ZX9R fighter
Post by Hogdigerdy Dog » Sat Sep 04, 2010 6:30 pm
Not sure about your misfire but to test the regulator/rectifier......
Test across the battery with a multi metre, if the rectifier/regulator is doing its job, you should have between 14.3 and 15.3 volts at about 3K rpm if not it may be the genny
test the battery across the terminals, a well charged battery should have 13.75 to 14.30V ish across it and tj's do like to have plenty of Amps
CRM
Admin NWAA
Admin NWAA
Post by CRM » Sun Sep 05, 2010 12:29 pm
should i move this to the Honda section ;) we get this question daily lol
Seriously there are some good tips up there, us Honda chaps are well versed in shit electrics (esp us ducati owners too)
Post by Evilchicken0 » Sun Sep 05, 2010 9:26 pm
Ah yes, I forgot to say if you suspect the recifier's dodgy then make sure you don't have a honda attached to it ... if you have then you need to change both defective parts
