Complete swap 3HE to 3EN2 frame
Henk88
Reactions:
Post by Henk88 » Sun Oct 06, 2019 11:31 am
Hi all,
Just bought a 3EN2, not running and without original fairing/seat. The idea was to swap all parts from my 3HE onto te 3EN2 frame but it seems the 3EN2 is more different to my 3HE than I thought (and not like the 3EN1).
Does anyone know which parts from the 3HE won't fit the 3EN2 frame? Tank cover and seat are different I've seen already. I'm also missing a mounting point for the lower right fairing (see image), but I read fairings should be identical?
https://ibb.co/TMCxMBQ
https://ibb.co/yQBXsRh
https://ibb.co/yF68k7Q
Reactions:
Re: Complete swap 3HE to 3EN2 frame
Post by Evilchicken0 » Sun Oct 06, 2019 6:35 pm
The main fairing should bolt on. As you've found the tail and tank are different but theres also an evolvment of the 3he over the years it was produced
Henk88
Reactions:
Post by Henk88 » Sat Oct 26, 2019 9:44 am
Seems I can't do the complete swap as I thought, need at least a tail fairing for 3EN2 with seat. Last weeks I was looking around for parts but for a 3EN2 seems hard to find, does anyone know a place where to find tail fairing/seat and maybe some other parts?
Another option would be to go for a 3EN1 frame, but then, apart from a small tail mod would it be possible to swap all parts (complete fairing) from my '92 3HE on a 3EN1 frame?
Reactions:
Post by Evilchicken0 » Sat Oct 26, 2019 10:40 pm
The front 3he fairing should swap to either 3en frame (you might need the subframe).
Would the 3he rear bolt to the 400 frame ???
