3TJ top engine bolts
- Reactions:
Anyone know the length of the M10 top frame/ engine bolts on a 3TJ? Mine are missing
- Reactions:
Re: 3TJ top engine bolts
You definitely want them
- Reactions:
- Bike owned: 2x3tj xs650
Hi
2x 40mm bolts and 2x 55mm bolts.
I think they are 10x1mm thread.
Neil
Neil
- Reactions:
Does anyone know the length of the lower engine mount bolt that passes through the side stand bracket ?
Sent from my SM-G950F using Tapatalk
- Reactions:
I'll find out in a day or so, I've got one fitted to a rolling chassis.icklepob wrote:Does anyone know the length of the lower engine mount bolt that passes through the side stand bracket ?
I have to get the rolling chassis out the shed and remove the bolt to measure it, I'll do it when the rain stops :)
Neil
- Reactions:
The lower bolt which goes through the sidestand mount is 185mm
The top rear engine mount bolt is 265mm and the Spacer bush which fits onto it is 57mm.
Written in text in case the pictures disappear one day :)
Neil
Neil
- Reactions:
Mega,thanks for taking the time to sort this info.
- Reactions:
Just remember those long bolts are wasted and the leg th is for the 3tj
- Reactions:
No worries, I'm pleased to help.
Neil
Neil
