oil consumption
Posted: Mon Feb 10, 2014 10:23 pm
by t-rex
Hi can anyone tell me what would be classed as normal oil consumption
Re: oil consumption
Posted: Tue Feb 11, 2014 9:34 am
by Evilchicken0
When it's not excessive :grin:
When youre topping up rather than "Using" oil. It really depends on how you ride, the amount of miles you're doing etc. Obviously check for oil leaks - the cam cover gasket sometimes weeps. After that check the plugs, see if they're oily that could be rings / bore wear. Look for a puff of smoke on start up suspect the valve oil seals. Check the crank breather pipe isn't pinched or kinked.
The only other thing would be to say these bikes are 25 years old, they weren't built to the tight tollerances of today's engines and so they use oil to fill those tollerances.
