660 stroker rods
Posted: Mon Jun 04, 2012 10:25 pm
Hello all, I have been a lurker on here for a while. But for those who make it over to the FZRarchives (sister bike site) I have been on there going on a decade now. I have an FZR400 with a YZF600r motor in it. I love this bike and have been riding my franken FZR/YZF for years now. It just keeps going... http://www.bikepics.com/members/nynoah/90fzr400/
Anyways, I am sure some of you have read about how we can make stroker motors with FZR600 cranks. But the problem everyone runs into is the rods. You can used YZF rods, but you need to make a base gasket and then find adjustable cam sprockets to line up the camshafts after the spacer plate knocks it all out of whack. Plus that then raises the head which messes with the top mounts. Parts and prices add up for a less than standard motor build. You can use the FZR rods and bore them out, but that is playing with fire and its a waste of machining costs in my opinion. Some guys have found a solution by using some Yamaha rods for the british Fazer. But they are hard to come by in the US and still just normal rods. So I am going to have a some forged rods made at the correct specs (modeled after the Fazer) which are going to have the FZR600 length and the YZF600r wrist pin size.
So to make this a little easier to understand, with the right rods, all you need is the FZR600 crank and a seal for the cases on the YZF600r or use the FZR600 bottom end and no seal needed. You can either run the FZR600 electrics or have a custom igniter box made from http://www.ignitech.cz/english/aindex.htm model SPARKER TCIP4. Which should be about roughly $300.
Can't beat that HP/tourque gain with a stick...
Anyways...
I have contacted a rod maker to make us some custom rods. I need to get 40 people in on this. I think between the FZRarchives, you guys and the 400greybike forum in England, this might be doable. The rods will be forged and able to take some abuse, which means that if you have the cash, you can get 1mm to 3mm over bore pistons and get this around 727cc. Time frame for this whole thing would be at least 90 days from 40 confirmed people. So this would be a great thing to invest in for a winter project.
Anyways if you want to read more from some of the guys who have done this. You can read some of these threads.
http://www.fzrarchives.com/ipb/index.ph ... opic=30847
http://www.fzrarchives.com/ipb/index.ph ... opic=50879
Price is going to be around $500 for a set of 4. Drop me a line if you are serious. Either on here or nynoah0@gmail.com Again, I am not a shop, just a guy who thinks the community needs this so I will make it happen. But I need at least 40 people to do that. I am hoping that between here, the FZRarchives and the YZF600r forums that we can do this.
Noah
Anyways...
Noah
