NC29 Battery
Posted: Tue Nov 13, 2012 12:54 pm
by Mickmac
My battery has given up the ghost , (it was a cheapy!!!)
Can anyone give me some advice what I should get and where do I get one from?, the bike doesnt get a lot of use but was started regularly NC29 1991
Re: NC29 Battery
Posted: Tue Nov 13, 2012 1:05 pm
by thunderace
YTX7L-BS. Varta are a good lead acid type and you should be able to pick one up for under £35. If you're splashing out, try £80 for a Lithium one from M&P.
Re: NC29 Battery
Posted: Wed Nov 14, 2012 11:18 pm
by Davez29
I can vouch for Varta agm as being brilliant but also a cheaper Lucas agm sounds and feels like it has a better CCA or Cold Cranking Amps than the Varta from my daily use. Starting just sounds more powerful in the Lucas.
In my battery drain post i mentioned I was using a Yuasa, i meant Varta but I have heard Yuasa are made in the same factory and are also good.
Re: NC29 Battery
Posted: Thu Nov 15, 2012 8:44 am
by GF Racing
Re: NC29 Battery
Posted: Thu May 10, 2018 9:16 am
by royster81
Just to 100% confirm the correct standard battery
for a gull arm nc29 is a ytx7l ?
