Does the CBR400RR use the same cam as the CB400RR?
Curious to know if Honda changed the CBR400RR cams to be higher performance cams. If they are the same, then I am safe to use any CB400RR thru CBR400RR cam in my project bike.
Thanks.
Brian
CAMS: CB400RR vs CBR400RR
Re: CAMS: CB400RR vs CBR400RR
Do you mean CB400 (NC31) vs CBR400rr (NC29)?
If so the nc29 cams are higher performance than NC31 and can be swapped, might need some other changes.
There's a cb400 racing in Oz that uses nc29 cams.
or did u mean nc23cams in a 29
i raced that cb...it isnt that quick
stimpy
stimpy
Is that Harleys bike Scott?
The CB needs all the help it can get!
How did it handle?
How did it handle?
yeah harleys bike...umm,i only saw it in front of me for 2 corners at wakefield in one race...and only on the startline in the others,i think i managed a second alap faster... it was quick for a cb tho,make no mistake
he's on an rvf now i think.
stimpy
stimpy
Thanks for the info and yes I was refering to the CB400 (NC31) vs the CBR400RR (NC29).
Just one follow up question here. What kind of performance differences are there between the two? Is it considerable or marginal?
Thanks.
Brian
Thanks.
Brian
I think you'll find that the power output is pretty similar, but the nc29 produces better power at higher revs (cams, compression, ignition, etc).bbanna wrote:Thanks for the info and yes I was refering to the CB400 (NC31) vs the CBR400RR (NC29).
Thanks.
Brian
you could never compare the 2 really in performance and handling..the cb that is racing here is heavily modified and is only just hanging onto stock nc23's and 29
summin to think about
stimpy
stimpy
