Nc24 gear box sometimes getting neutrals in 4th 5th and 6th
Pirates Cove
Post by Pirates Cove » Sun Jan 11, 2009 12:07 pm
Hi.
I have an VFR 400 with NC24. Today I did the somoeng loop , which is a 100km of twisting roads outside Chiang Mai Thailand. Perhaps four or five times once in fourth and once in fifth and the rest in sixth when I changed up a gear it selected neutral (or spun freely).
In each case selecting up engaged the gear correctly. I believe that each time I upshifted lightly sometimes with clutch sometimes without.
It has never happened on downshift or when I have forcefully changed up. What could be the problem ?
Thanks Mark
castrol101
Re: Nc24 gear box sometimes getting neutrals in 4th 5th and 6th
Post by castrol101 » Mon Jan 12, 2009 12:01 pm
I don't think there really is a problem...Sometimes if you don't upshift positively the gear doesn't quite engage and you just end up in a false neutral. As long as it doesn't jump out of gear under acceleration then i think all is well....
Post by Neosophist » Mon Jan 12, 2009 11:17 pm
False neutrals, upshift more firmly.
Sligeach
Post by Sligeach » Tue Jan 13, 2009 1:56 am
yip, probably just false neutrals due to not being firm enough with the upshift.
try adjusting the gear lever down so it takes less movement to be positive on the upshift
Pirates Cove
Post by Pirates Cove » Sat Jan 17, 2009 2:28 am
Hi all.
Yeah apparently I was being a little gentle and thats it :)
Operator error!
Thanks Mark
Manticorp
Post by Manticorp » Mon Jan 19, 2009 12:15 am
Just a little tip:
If you ever false neutral change up and not down ^^
I've known a couple of guys who have come out of corners v.badly after shifting down out of a false neutral. It aint pretty :P
Hehe just keep those shifts nice and hard ;)
H
