NC30 Clutch cover compatibility with NC24/21
- Reactions:
Dear all,
I now have the go ahead to fix my daughters NC30 to fix after she got wiped out by a taxi There is no rush as she has a broken foot but I'd like to start sourcing the parts. The clutch cover housing is badly cracked so I need to get hold of a good second hand replacement. Lots of NC21/24 items on ebay but only one NC30 item that is pickup only so not much use to me right now! Can anyone confirm if the NC21/24 items will fit?
Thanks!
Keith
Thanks!
Keith
- Reactions:
Re: NC30 Clutch cover compatibility with NC24/21
Interesting question. Will it fit physical, cant see why not as there both nc13e engines.
will it work?
well The NC24 clutch cover has a shamfer on the clutch part but i believe they both use the same clutch basket so it shouldnt interfere with anything, the dipsticks are in different places from memory, the 24 is in the middle and the 30 is closer to the edge... so if you do try one make sure it has dipstick with it and hope it dosnt hit anything. cant see what it would do but not 100%
will it work?
- Reactions:
Iirc the dipstick are in the same place on both models,but the nc24 has a oil filler cap on the top....so if not able to fill through that you can still fill through the dipstick hole...
