I have an '86 NC21 and the clutch was apparently not too good according to the guy I bought it off - but recently it started slipping quite noticeably so today I took it apart.
It had 10 x 3.0mm friction plates and the plain plates were pretty blue and quite thin at 1.5mm thick.
I did have a spare clutch pack from another NC21 and it looked pretty good with friction plates that measured up well within tolerance and nice shiny dimpled plain plates.
But although I used it and it seems OK on a quick spin up the road - it wasn't exactly the same...
Although the pack measured the same - this pack has only 9 friction plates and the plain plates are twice as thick at 3.0mm and the innermost friction plate has a much larger bore than the others (about half of the friction area).
Anyone else come across this?...and any idea why Honda put the odd half plate in?
NC21 clutch types query...
