what's the part number?
ligurt
Reactions:
Re: what's the part number?
Post by ligurt » Wed Dec 12, 2018 7:53 pm
this is it
Reactions:
Post by CMSMJ1 » Wed Dec 12, 2018 9:54 pm
Look on the red sealed bit of that bearing - you might see the code for it
Faxe400
Reactions:
Bike owned: VFR400RH, VF1000RG
Post by Faxe400 » Thu Dec 13, 2018 10:29 am
Or it is lasered into the outer metal ring. Just from looking at the pic I would assume it is 6004 (42 mm outer diameter, 20 mm axle, 12 mm wide).
Did you try to get the bearings out? I see no place for shaft seals. On my Honda rims there is place to install the shaft seals into the rim.
JZH
Reactions:
Bike owned: RSCBRRVFVFRST
Post by JZH » Tue Dec 25, 2018 6:03 pm
Most bearings used on Hondas are "standard" automotive/industrial bearings, which means that they come in standard sizes and are identified by standard bearing codes, e.g., 6004 (Honda pn 91054-MN8-741), 32006 (Honda pn 91016-KT8-005). This web page (http://www.vsource.org/VFR-RVF_files/BBearings.htm) concerns my VFR750FP, but you will find that the NC30 shares a lot of the same bearings and seals. Some bearings are Honda-only, so most bearing suppliers won't be able to help, but there are sometimes alternatives that can be used.
Ciao,
JZH
JZH
London, UK/So.Cal., USA
www.vsource.org
ligurt
Reactions:
Post by ligurt » Sat Jan 19, 2019 5:10 pm
Want to thank you all for the great help.
This is the ral meaning of the forum.
Ciao
Pietro
