However, getting a bit bogged down in identifying which are the inlet/exhaust valves.
Photo below is of the left hand side of the engine with the cylinder head cover removed, so carbs go in the RHS of the photo and exhausts come out LHS.
So my logic says LHS valves (as you look at pic) should all be exhausts and RHS ones should be inlets, but as you can see this doesn't match the machined labeling!
My very patient but stubborn 'repair supervisor' (read 'boyfriend'!) insists that I should believe the labeling on the engine, but when cranking the engine round by hand it appears that both the valves marked 'EXL' in this image are open at the same time. So... they can't possibly both be exhausts... right!?
Anyone come across this before?
Any advice much appreciated!
