NC30 Stop/Tail light issues (SOLVED)
Reactions:
Bike owned: VFR400
Re: NC30 Stop/Tail light issues (SOLVED)
Post by magg » Tue Nov 13, 2018 11:08 am
Simplysideways, the same issue, both stop lights on unless you press either the front or rear brake levers and then they go out?
Simplysideways
Reactions:
Post by Simplysideways » Tue Nov 13, 2018 8:53 pm
They don’t go out they slightly flicker
Reactions:
Bike owned: VFR400
Post by magg » Tue Nov 13, 2018 10:15 pm
So lights OFF, ignition ON and stop lights come ON immediately and pressing front or rear brake levers causes stop lights to flicker.
Simplysideways
Reactions:
Post by Simplysideways » Wed Nov 14, 2018 12:26 pm
My lights are permanently on when the ignition is turned on ( from memory lol only picked up a few weeks ago and only had the tail cone on once ) , the taillights are extremely bright and when I press the brake there is a slight change/ flicker in brightness.
I’m up in Cairns at the minute and the bike is in Brisbane so I won’t get a chance to have a look at it until the weekend again , depending on what the wife has in store for me when I get home lol.
Cheers mate
Reactions:
Bike owned: VFR400
Post by magg » Fri Nov 16, 2018 3:14 am
NC35 is lights on always, NC30 not. You have an NC30 or an NC35?
Simplysideways
Reactions:
Post by Simplysideways » Sat Nov 17, 2018 9:28 am
It’s def an NC30 jap import , lights are permanently on . There is no switch to turn them off .
Reactions:
Bike owned: VFR400
Post by magg » Sat Nov 17, 2018 11:09 pm
The left handlebar switch should have three positions, Dot (off), P (park) and H (headlight). Not aware of any NC30 with lights always on.
Simplysideways
Reactions:
Post by Simplysideways » Mon Nov 19, 2018 10:39 am
Mine must have been swapped out at some stage because where your talking about is blocked up , Gonna be looking at a RVF to buy during the week so i’ll Have something to compare to .
Reactions:
Bike owned: VFR400
Post by magg » Mon Nov 19, 2018 9:40 pm
The switches do fail when high wattage bulbs are used as there is a relay on only high beam, and people use an NC35 as a replacement. Needs some rewiring to work and may indicate that there are other wiring idiosyncrasies.
Simplysideways
Reactions:
Post by Simplysideways » Sun Dec 09, 2018 1:13 pm
Thanks mate ,
I ended up buying an RVF400 so the missus can ride it due to her license , needs a few bits doing so gonna focus on that for now and put the VFR in storage and make it a long term project / use as a spares bike
Def an RVF switch fitted so I’ll prob chase us a proper switch for it , guessing as with a lot of Honda parts they are generic between different models of that era CBR400rr/CBR250rr
