NC35 Swingarm mount dimensions
GezzaPom
Bike owned: Honda XL600RMG
Post by GezzaPom » Tue Mar 22, 2016 1:32 pm
Hi all,
I could do with a little help with a project that I have just started.
I have an XL600RMG that I am doing a major custom job on. Front end has been swapped over to an 05 ZX10R and now I am looking to fab on a NC35 rear end. It should fit in with only some simple mods but, unfortunately I do not have access to a Nc35 to measure the pickup points for the rear end and I have spent a few weeks searching the internet to find these dimensions, but, to no avail. So if anyone can help stop my head hurting and pull out a steel rule help me fill in the blanks, it would be greatly appreciated.
These are the dimensions that I am looking for:
Height of Pivot point at ride height (I believe it is 400-420. Please correct me if I'm wrong)
Using the Pivot point as a datum, I need the following:
Shock absorber top eyelet
Dogbone link to frame hole
I only need fore and aft and height in relation to the pivot point. The lateral dimensions will become self explanatory once the arm is in place.
Thanks in advance
GezzaPom
Re: NC35 Swingarm mount dimensions
Post by GezzaPom » Sat Mar 26, 2016 10:13 am
Well, I've got this far but I could really do with the dimensions for where the dogbone link attaches to the frame.
I would like to put it in the same place as the RVF so the shock is working at the correct ratio and any changes I make will be comparable. Rake is 25 degrees and wheelbase is 10 shorter than the RVF. This isn't going to be a race bike, just a weekend ride.
If anyone could help me with that dimension, it would be greatly appreciated.
