Fan kicks in and works fine.
The gauge is also working as I have earthed the wire at the thermostat housing and it shot up as you would expect
The problem is that when the bike is running the gauge doesn't budge at all! I am putting this down to either a faulty sender or thermostat but am asking others to find out firstly if you have had the same issue and secondly what remedied it? A new thermostat is 50 quid so don't want to buy one, spend all the time installing it for it to not be the solution.
I spoke to a motorbike mechanic who seemed under the impression that the sender and thermostat itself are not separate?? I cant see how this is possible though...
Over to you guys
