NC30 Kill switch rewiring - Is this a bad idea?
lukemillar
Post by lukemillar » Fri Oct 03, 2014 10:18 pm
Hey
My NC30 racebike is almost back together but my replacement top yoke with ignition barrel is shot. I want to swap out the whole thing with a switch as I don't have a key and was thinking I could just rewiring my kill switch to be the ignition switch. I'll hardwire/remove the current kill switch behaviour and then just hook up the ignition so obviously it'll still work as a kill switch
Is this a bad idea? Thoughts?
Luke
Fitty
Re: NC30 Kill switch rewiring - Is this a bad idea?
Post by Fitty » Sat Oct 04, 2014 12:44 am
Isn't the kill switch pretty crucial in a stack?
lukemillar
Post by lukemillar » Sat Oct 04, 2014 1:44 am
Yes, but it'll still work as a kill switch.
The standard kill switch just kills the spark, so you can turn the engine over on the starter but not have it fire. What I intend to do will be the same as if the bike was running and you turned the key off
Post by Neosophist » Sat Oct 04, 2014 4:18 am
id still keep a secondary kill swithc somewhere just incase your switch fails, espeically after a crash or something and yo ucant turn the bike off.
lukemillar
Post by lukemillar » Tue Oct 07, 2014 4:34 am
I'll add a tether kill switch as well
