O ring sets
damedichi
Bike owned: KTM 990 Adv and NC29
O ring sets
Post by damedichi » Wed Jul 16, 2014 12:34 pm
Can anyone recommend a good O ring set, for multi purpose uses on the CBR?
For example, to replace carb drain screw O rings, amongst others.
Or will any set I can pick up from flea bay, Amazon etc do?
DocV400
Bike owned: 1200 Bandit ~ NC30 ~ Italjet
O ring sets
Post by DocV400 » Wed Jul 16, 2014 5:05 pm
In my experience (and opinion), you're better off buying just the O-rings you need, rather than a set.
The sets look to be good value, but they tend to be low quality items (unless you pay a lot), and you always end up with loads you'll never need/use.
I've used this site several times . . .
http://simplybearings.co.uk/shop/index. ... =4501_4705
They're good for Bearings too.
You'll need to be able to accurately measure the O-ring(s) you need (or the space/part it's going in/on/around), a decent enough Digital Vernier Caliper can be got for around a Fiver, and will be useful for plenty of other jobs too . . .
http://www.ebay.co.uk/itm/150mm-6-Inch- ... 2c86689e41
A Pessimist is just an Optimist, with experience.
Doc out . . .
SulleysBoss
One Hit Wonder
Re: O ring sets
Post by SulleysBoss » Tue Jul 22, 2014 8:29 am
You also need to be aware of the material the O rings are made of, some will not stand up to petrol.
DocV400
O ring sets
Post by DocV400 » Tue Jul 22, 2014 2:13 pm
Yes, my bad, should have linked to the Viton O-Rings . . .
http://simplybearings.co.uk/shop/index. ... th=19_4462
Doc out . . .
Maelstrom
Bike owned: MC22, 3TJ1
Re: O ring sets
Post by Maelstrom » Wed Jul 23, 2014 1:19 am
Maybe not what you are looking for but if you need full carb kits at some time.
viewtopic.php?f=64&t=42551
cheers
Blair
https://litetek.co
