Exhaust manifold nuts.
simes205
Bike owned: Vespa 300GTS, NC30
Post by simes205 » Thu May 22, 2014 9:33 pm
Hello,
I keep finding (since ownership) that the exhaust manifold nuts on cylinder 1&3 keep working loose a and coming right off. Initially I thought the tapping noise was valve clearances needed doing but after finding the nuts near the rear spring well that fave it away
I've done them up 3 times in 3k kms - but really I shouldn't need to
I'm scared to over tighten them it tbh I do them up fairly tight. I can't get my torque wrench in there unfortunately.
Should these nuts be replaced each time?
Is this a trait of nc30's to work loose?
Any tips to stop it happening?
kawasakiinit
Re: Exhaust manifold nuts.
Post by kawasakiinit » Thu May 22, 2014 9:38 pm
would it be possible to remove them and fit 2 standard nuts so that you can lock em together once tightened if you know what i mean
my other freedom
simes205
Post by simes205 » Thu May 22, 2014 9:47 pm
Mm.mm not thought of that but tbh it's hard enough getting one on there!!
On a car they are normally brass but these aren't.
kawasakiinit
Post by kawasakiinit » Thu May 22, 2014 10:06 pm
what about some of these bud?
[URL=http://s639.photobucket.com/user/k ... .jpg[/img][/url]
my other freedom
Post by Neosophist » Fri May 23, 2014 8:16 pm
simes205 wrote:Hello,
Tighten them up properly, certainly not a trait.
Never had any come undone before that were put on tight enough. It's Only reason I can think of is they are not tightened enough.
rear cylinders? do you mean the stubby or the pipes to stubby? genuine or aftermarket system?
Morespeedvicar
Post by Morespeedvicar » Sat May 24, 2014 2:02 am
or use some plain and spring washers.
In stainless of coarse.......
simes205
Post by simes205 » Sat May 24, 2014 7:34 pm
Nice one,
Simon
