Nc35 LH switchgear replacement-ideas please
Posted: Thu May 08, 2014 9:15 pm
by racingt
Hi guys, horn stopped working, believe switchgear is faulty. Planning to dismantle and clean up, if this doesn't work, is there a source of new switchgear? Or a substitute Honda item?
Thanks for assistance.
Re: Nc35 LH switchgear replacement-ideas please
Posted: Thu May 08, 2014 10:10 pm
by code2006
U could try every
Not sure if David silver spares does them
There's also another website but can't remember at the moment
Posted: Thu May 08, 2014 11:37 pm
by racingt
David silver hasn't got any, I think these are rare. Someone must recon them?
Posted: Fri May 09, 2014 2:00 pm
by Davez29
The The later nc29 switches are the same apart from plugs so will work but you need to swap pins around and use the original plugs.
If your really desperate there are Chinese copies sometimes on ebay.
Posted: Sat May 10, 2014 10:20 am
by alexandervf
You could also use,
cbr900 (sc33), cbr929,....and many others.
I personally, bought and use a sc33 LH switchgear. But, as durka durka previously said. You will have to change the pin-out in order for them to function properly.
I don't think any of them is plug n play.
Posted: Sat May 10, 2014 2:58 pm
by racingt
Thank you guys.
