Running like sh*t after a needle change
Posted: Fri May 02, 2014 2:42 pm
Hi all,
Here's the facts:
- I've swapped the original needles for RO needles.
- Originals were:
- Front Right: 115 J51B
- Front Left: 115 J51B
- Rear Right: 118 J51A
- Rear Left: 115 J51A
- All emulsions/pilots in the correct holes
- New float gaskets
- Have *not* done the 2.5mm hole in the slides
- Have balanced the carbs, one of them was really out
- Pilot screw is 2.75 turns, it was quite different to that before...
Anyway, the bike has never ran perfectly as I've never adjusted the carbs. Completed this mini-rebuild and she's running worse. The revs are hanging, but after spraying some carb cleaner about I've found one of the front rubbers has a very slight air leak as the revs rise for a few seconds. Took fooking ages to get her to start this morning, several bump starts got her going, but since the mods, after she's got slightly warm, she cuts out! Here's a video of the issue:
https://www.youtube.com/watch?v=OaVQ7lZDUyo
Bit of a petrol smell about (but they always do), can't decide if it's more than usual. I know there's a slight air leak that I'll fix on Monday if I get time, but I thought an air leak would make the revs high, not cut out? So I'm thinking the air leak is responsible for the erratic revs, but not sure why the cut out - possibly running too rich? I put a sheet of paper at the can and revved her (free flowing full tyga system with a maggot can for now), after a while the paper was a bit moist with what looked like dirty black water or soot.
I'm going to whip the tank off on Monday, hopefully I don't need new rubbers and it's just a case of re-seating, but I'm not sure how to lean out the mixture with the carbs in place.
Here's the facts:
- Originals were:
- New float gaskets
