No spark
Delboy
No spark
Bike was running fine last week, parked up, no problems.
Went to go out the other day, turns over but no spark?
Got power going to the coils, have swapped a known working CID unit and still no spark....help!
richyrd5
Re: No spark
Hey dave.whats the battery like?is it turning over the motor fast enough?.if iit was running fine one minute then not it is sonething like a broken wire or something silly.check everything again.and try different plugs as they can just give up!!
Delboy
Re: No spark
It turns over really well, not getting a spark at all
richyrd5
Re: No spark
Just go through everything well.check kill switch/ignition switch.pick up wiring etc.will probally be something loose/broken.!!
- VFRkieran
Re: No spark
Sounds very similar to the problem im having, get a multimeter and check the resistance to your pulse generator coils, ive just checked mine and ive got infinate resistance when it should be 4-500ohms, easy to check too and it seems like its often overlooked.
- V4beermonster
Re: No spark
been over tonight to have a look pulse gen is dead on the yellow/white side so He's after another 1 if anyone can help??
- VFRkieran
Re: No spark
Good luck lol I need some too.
Delboy
Re: No spark
I've managed to get one off ebay £31, picking it up tonight from Brum
Cheers for having a look Phil, top bloke
- V4beermonster
Re: No spark
No problem pal anytime
