Font suspension upgrade (675?)
benny
Bike owned: NC30 (track), ZX-9R (road)
Post by benny » Sun Apr 13, 2014 6:10 pm
What's the best option moving up from upgraded RO internals?
ZXR400 or NC35 swap? I can't find much information on ether, but i've had a quick go on an NC35 swapped biked, so i know about the steering lock issue. But as its for race/track use only I'm interested in peoples oppinions. (I wouldnt call it a test ride as it was only round the paddock)
DM104 for the road race team.
Re: Font suspension upgrade
Post by Drunkn Munky » Sun Apr 13, 2014 6:29 pm
Neither of those would be a upgrade worth doing over a good set of nc30 forks unless you just wanted usd's. An upgrade would be 675r forks
benny
Post by benny » Sun Apr 13, 2014 7:19 pm
Drunkn Munky wrote:Neither of those would be a upgrade worth doing over a good set of nc30 forks unless you just wanted usd's. An upgrade would be 675r forks
Do you get any noticeable advantage to USD forks?
(edit to add: probably not)
benny
Post by benny » Sun Apr 13, 2014 7:22 pm
Ok basically, i want to upgrade my front suspension but only have to do it once!
Cammo
Post by Cammo » Mon Apr 14, 2014 12:15 am
The late model nc30 forks are excellent when setup properly, particularly on the track (more of a compromise on the road when compared to newer stuff).
What's the problem with yours? Are the forks in good condition - a good clean, new oil & bushes, sag set up properly for your weight? Have you tried adjusting them to suit track conditions?
JC120
Post by JC120 » Mon Apr 14, 2014 11:59 pm
The Daytona 675R forks won't fit the NC35 triples. The olins bottoms are 54mm. The NC35 has 52mm. Regular 675 forks are 52mm though. I measured them. Maybe your talking about the Sreet Triple 675R which I assume would fit.
V4ia addict
benny
Post by benny » Sun Apr 20, 2014 10:35 pm
Think I'm going to go for 675 forks, will street triple do?
Cammo
Re: Font suspension upgrade (675?)
Post by Cammo » Sun Apr 20, 2014 11:14 pm
Street triple forks aren't very adjustable, stick with daytona 675 (or street triple R).
28hodge
Bike owned: nc30 (track) Yam YZ250 (MX)2st
Post by 28hodge » Mon Apr 21, 2014 9:39 am
Street triple also don't have radial caliper mounts whereas the 675r do, I think the or street triple r also has radial caliper mounts but I'm not 100% sure
Cammo
Post by Cammo » Mon Apr 21, 2014 11:04 pm
Yep, street triple R also has the radial calipers
