rear wheel siezed on. help would be appreciated.
talcumpowderbut
Post by talcumpowderbut »
Rear wheel seems to be siezed on. And the spacer for that matter. Any tips on getting the bugger off? Thanks
Delboy
Re: rear wheel siezed on. help would be appreciated.
Post by Delboy »
Rubber mallet...or block of wood and a lump hammer...basically, it's gonna need a good wopping...when you do get it off, use copper grease when you put it back on...
talcumpowderbut
Delboy wrote:Rubber mallet...or block of wood and a lump hammer...basically, it's gonna need a good wopping when you do get it off, use copper grease when you put it back on...
Thats great. I get to use my favourite tool. thankyou.
CRM
Admin NWAA
Admin NWAA
Post by CRM »
has the wheel been powder coated ? if so get a dremel on the inner surface to ensure it does not happen again,
you need to get brutal, you can prise it too slowly, but you will chip paint use the 4 nuts you can just make out to get a leverage between and the wheel.
talcumpowderbut
CRM wrote:has the wheel been powder coated ? if so get a dremel on the inner surface to ensure it does not happen again,
It has been powdercoated and yet i will get at it with a dremel when its of. Gave it a good bashing and still no movement so will try to lever it off next time i am at it. Like you said. Cheers
tigerclaw
Post by tigerclaw »
Or take it for a ride... :grin: just kidding ... dont do that :?
talcumpowderbut
tigerclaw wrote:Or take it for a ride... :grin: just kidding ... dont do that :?
Great thanks. Never thought of that. Will give it a try and get back to you on how it works :P
NGneer
Post by NGneer »
Assuming it is up on aa ABBA stand so it is not going to fall over, get a mate to 'steady' (or sit on) the bike then sort of sitting on the floor use the heel/sole of your foot and get all medievil on the back wheel :twisted: (remember to wear shoes) :? .
Aim your kicks as far out as possible (tyre/rim) to maximise the leverage and if you have had your weetabix you should be able to break the 'sticktion' and then the thing should just fall off :grin: :grin:
talcumpowderbut
NGneer wrote:Assuming it is up on aa ABBA stand so it is not going to fall over, get a mate to 'steady' (or sit on) the bike then sort of sitting on the floor use the heel/sole of your foot and get all medievil on the back wheel :twisted: (remember to wear shoes) :? .
Thanks sounds like not a bad idea. Cheers. I have photos of that yamamoto link pipe will try and get them ip for you tonight mate. Im getting mine repaired from rcv4 so cant sell it to u unfortunatly but will get pics up. Sorry for the delay have been real busy at the moment. cheers connor.
NGneer
Post by NGneer »
talcumpowderbut wrote: I have photos of that yamamoto link pipe will try and get them ip for you tonight mate
Ooooh - I had forgotten about that - but would be good to at least have a picture of one. Cheers :peace:
