Page 1 of 3
CONFUKULATED REGARDING DERESTRICTING
Posted: Sun Mar 31, 2013 5:45 am
by Jac-al
Morning guys,
im very confused. A few months ago i did the derestricting mod behind the clocks by cutting the tab away. This morning i decided to hook up my gps to my yolk to check what top end i get. guess what, its wouldnt go over 186km/h and definately felt the limiter. i really dont understand as i followed all the steps and my bike revs all the way to almost 16k rpm in every other gear. what do u ppl think is goin on? i swear this bike is possessed
Re: CONFUKULATED REGARDING DERESTRICTING
Posted: Sun Mar 31, 2013 7:47 am
by Jac-al
Nobody got any idea?? could my CDI be fooked?
Posted: Sun Mar 31, 2013 8:08 am
by Drunkn Munky
I've never done that mod but my guess is you haven't done it properly, isn't it easier just to add a resistor to the wiring?
Posted: Sun Mar 31, 2013 8:25 am
undo the speedo drive cable and then see how fast it goes on the GPS.. If the speedo cannot tell the CDI it is going over 180 then you should have no restriction.
Posted: Sun Mar 31, 2013 10:12 am
by thunderace
Doesn't the NC30 CDI go into "limp mode" if it doesn't see a speedo drive signal?
Posted: Sun Mar 31, 2013 10:42 am
by magg
"Limp mode" is the result of the failure of the ignition control unit to detect the speed sensor electronics in the speedo. This happens when the speed sensor electronics fails or is disconnected. As CMSMJ1 said, undoing the speedo cable will remove the speed limiter function but retain the sensor, so the ignition control unit will remain happy.
Posted: Sun Mar 31, 2013 11:24 am
by Jac-al
took the clocks apart and went thru the instructions again. ive done it right. now i remember it wouldnt go past 12.5k rpm in 6th but i took it to 14.5 last week so im lost. ill try with the cable disconnected. keep u posted
Posted: Sun Mar 31, 2013 11:51 am
by Jac-al
could a fookt alternator cause this? I did the charging test and it points to a faulty alternator. bike is dead every morning
Posted: Sun Mar 31, 2013 1:18 pm
by magg
If you are now getting 14500 rpm in 6th then I doubt the speed limiter is cutting in. A 2000 rpm increase in 6th should raise 186kph to somewhere near 215 kph. Does your speedo indicate higher than 190kph, my restricted import only has a 190kph speedo. Sure your speedo can indicate more than 190kph?
An engine that revs to 14500 rpm in 6th obviously isn't worried by a dud charging system. What test did you do to determine the alternator is knackered.
Posted: Sun Mar 31, 2013 3:58 pm
by Jac-al
with speedo disconnected i got 202km which is still under what it should isnt it? why when its connected i only got 186km and wouldnt rev more than 12.5rpm but last week it revved to 14.5rpm
