Oil leaking
Jac-al
Oil leaking
Post by Jac-al » Sat Nov 03, 2012 1:53 pm
Hi, I had an accident 2months ago where my NC30 flipped over, luckily only cosmetic damage. Since the accident the bike was running well although It had a little too much oil. All of a sudden now the bike is leaking oil, It looks like its coming from behinf the cover where the gear change pedal is bt the front sprocket. I cleaned it yesterday and went for a ride, the gears were rather hard to shift and when I got back there was oil allover the sump and even on the swingarm and and also a little on the plugs, its also making a tickin noise. Pls help, I don't wanna ride it anymore incase I damage something
hunter
Re: Oil leaking
Post by hunter » Sat Nov 03, 2012 2:11 pm
Sounds like you may have bent the gearchange shaft and the oil is leaking past the seal.
0r you have damaged the case.
Jac-al
Re: Oil leaking
Post by Jac-al » Sat Nov 03, 2012 6:38 pm
Howsit, just took it for a ride and there's no power and its making a horrible noise, the tickin has gotten louder too. Soiunds like somethings given in. Another odd thing is everytime I check the oil its different, ranging from full to empty. Could I have blown something?
Dynamohum
Re: Oil leaking
Post by Dynamohum » Sat Nov 03, 2012 7:20 pm
is there a strong smell of fuel coming from the oil filler cap ?
Jac-al
Re: Oil leaking
Post by Jac-al » Sat Nov 03, 2012 7:45 pm
My bro says he thinks there is, I haven't taken notice. I'm gonna go check in a bit, if it does is that a bad thing? Or should I ask how bad?
Jac-al
Re: Oil leaking
Post by Jac-al » Sat Nov 03, 2012 8:18 pm
Just checked it out and yes, it does smell like fuel. What could the damage be?
Re: Oil leaking
Post by Neosophist » Sat Nov 03, 2012 8:52 pm
I will put money on that the engine is ruined.
Never run an engine that is making odd noises until you have checked the oil is clean and full.
Your oil should change between full and empty unless your measuring it wrong... where did it go?
Jac-al
Re: Oil leaking
Post by Jac-al » Sat Nov 03, 2012 9:03 pm
The oil is clean, I did a change about 500km ago and I keep puttin in if it shows its low. My bro said the bike did the same thing last week and then just came right on its own. Very confused now
xivlia
Bike owned: Ducati 749 D
Re: Oil leaking
Post by xivlia » Sat Nov 03, 2012 11:27 pm
if there is fuel smell coming from the oil.. then your fuel has mixed in with the oil. this happend to me once. dont run the bike, the viscosity of the oil will be lower than it should be because its mixed with petrol. chances are.. engine ruined. i used to have an old 125 cc scooter and it was a pile of shit, and it was on its way to the scrap yard, so i decided to run the bike with no oil. guess what happend? strange noises, ticking, clashing, cloking.... then *CLONK* engine got jammed. wouldnt turn over anymore. it was an experiment i wanted to do. so dont start flaming me.
Dynamohum
Re: Oil leaking
Post by Dynamohum » Sat Nov 03, 2012 11:44 pm
How much oil was put in at the oil change and subsequently after in 500km use?
