Page 1 of 2
Effect of discs past minimum thickness?
Posted: Sun Oct 21, 2012 6:47 pm
by jetblack
Just wondering if discs that are worn past minimun thickness actually perform worse (cant dissapate as much heat, perhaps?) as thicker discs? Mine are almost down to min but will probably last a few more miles yet. And at £120 a pop id like to get as many miles out of them as poss! Any thoughts?
Re: Effect of discs past minimum thickness?
Posted: Sun Oct 21, 2012 9:55 pm
by lukemillar
Probably more prone to warping as well
Posted: Sun Oct 21, 2012 10:13 pm
by lutorm
I guess the thing you really don't want to happen is that they get thin enough that they can't take the brake force and come apart when you try to pull a panic stop. That would really ruin your whole day.
Posted: Mon Oct 22, 2012 9:13 am
by thunderace
Put it this way, is your life worth so little?
Worn discs are more prone to warping, splitting, over-heating. All things that reduce braking performance.
I have a picture somewhere of a write off bike I picked up a while ago where the owner had run on discs only 2.5mm thick. He didn't manage to stop when the dustbin wagon pulled out - the discs shattered as soon as he pulled the anchors on (according to eye witnesses).
Posted: Mon Oct 22, 2012 9:40 am
by Triplespeed
As above but would there be a possibility that if you had thin discs and thin pads would they not generate enough clamping force?
Just an idea but I have always changed out braking equipment as a priority
Posted: Mon Oct 22, 2012 9:48 am
It is a higher risk of failure.. not something you want on a bike is it?
Posted: Mon Oct 22, 2012 7:33 pm
by jetblack
oh god, i'm not suggesting using them past min thickness, they're a little way off that yet.
I just want to know if the braking effect is reduced the thinner/closer to min thickness that they get or does the braking efficiency not directly correlate to the efficiency?
Posted: Mon Oct 22, 2012 9:46 pm
by speedy231278
I guess if you put too much thought into it, you could say that thinner discs mean they'll get hotter quicker, and be more prone to fade, but then if you're pushing a road bike hard enough to make the brakes go soft then perhaps you might want to find a racetrack!
Posted: Mon Oct 22, 2012 10:00 pm
it is the small cracks in them that worry me.
Have a proper good look at them - you get cracks in old rotors from hole to hole.....
Posted: Tue Oct 23, 2012 1:15 am
by Morespeedvicar
And it wont pass its next mot..............
