NC30 Fender Threads
NC30 Fender Threads
They dont appear on the parts list however can you buy the threads that rivet onto thw front fender?
- thunderace
- Bike owned: R6, YZF600R
Re: NC30 Fender Threads
You got a pic of the part you mean Ricky? I can't visualise it.
I dont as i have a carbon fender and have to struggle with using nyloc nuts everytime i want to take the bugger off.
The 4 holes to which the fender attachws to to the nylon fork brackets on the oem fender has 4 m6 threaded bita that are riveted in place.
Rick
Rick
- thunderace
Ah, I know what you mean. They are just generic. You can get them, I had some not so long ago. I'll dig out the invoice and let you know where I got them from.
Brilliant, cheers stevethunderace wrote:Ah, I know what you mean. They are just generic. You can get them, I had some not so long ago. I'll dig out the invoice and let you know where I got them from.
You mean the inserts?
http://www.ebay.co.uk/itm/M6x12-0mm-Hea ... 3f143e028b
like this right.
Is there any space to fix them on your carbon fender?
like this right.
There not them, there like a tear drop shape with m6 hole/thread and a 3mmish hole for a pop rivetNeosophist wrote:You mean the inserts?
like this right.
Ah I see, I thought the mudguard used stock inserts straight into the plastic like the ones I pasted, not riveted on, never paid that much attention to them.
Don't you have your old mudguard? You could always drill the rivets out and remount them.
I used helicoil threads in a fibreglass guard I had, worked a treat.
I have rivnuts but you will need the tool to insert them.
