nc23 headlight setup
Posted: Sun Aug 26, 2012 4:35 pm
by willpisme
Hi all,
Pretty simple question but i have no reference to go by to work it out! Ive checked the haynes and theres nothing on it and cannot recall seeing another nc23 with its lights on at least!
Off in for the bikes first MOT in 4 years after building it up this year.
The sidelights work completely fine
when i go to dipped beam the right light is dipped and the left light is on sidelight
then when i switch to full beam both lights are full beam.
Is this correct? it just seemed strange that the right light was the only one on dipped??
Cheers for any help!
Re: nc23 headlight setup
Posted: Sun Aug 26, 2012 5:07 pm
by petrolhead19
Sounds like your dipped beam on the left hand bulb is popped, get a new bulb for it should sort it out
Posted: Sun Aug 26, 2012 6:52 pm
by willpisme
cheers i thought as much!
Any recommendations for headlight bulbs? already got LED's in the sidelights so may go for something similar.
Posted: Mon Aug 27, 2012 10:59 pm
by petrolhead19
willpisme wrote:cheers i thought as much!
Wouldnt bother with led headlights, if you want to go away from original fit a hid kit but if its not done right it can burn out fuses and light controls.
I would just get another set of original bulbs mate but with using uk bulbs you might need to do the low beam relay mod or it will eventually burn out your light controls.
GF does original
http://www.gfracinguk.com/headlamp-bulb ... -p-14.html
link for the relay mod, i still need to do it on mine
http://www.vsource.org/VFR-RVF_files/NC ... mRelay.htm
Posted: Fri Aug 31, 2012 11:44 am
by willpisme
thanks a lot mate, good advice once again!
bought two H4's Uk spec in the end so need to get that relay mod done asap!
cheers
Posted: Fri Aug 31, 2012 12:27 pm
by thunderace
petrolhead19 wrote:willpisme wrote:cheers i thought as much!
Problem with HID is that unless you fit complete headlamp units, it will be an MOT failure. All aftermarket kits that don't include the reflector assembly are illegal for road use in the UK. I've never seen any for sale for any 400s, or anything pre about 1996 for that matter.
