Drilling Swingarm for brake line
Posted: Sun Feb 12, 2012 11:07 pm
by Tomzed
Hi guys I was wondering if there was any info on this I've done a search but not found a great deal.
How big are the holes you drill? Where exactly do you drill them? And does this weaken the Swingarm caused anyone any trouble with mot etc
Any help is much appreciated
Re: Drilling Swingarm for brake line
Posted: Sun Feb 12, 2012 11:58 pm
by lizard821000
think ricky(porndog) done this mod mate, try giving him a pm. sure he wouldnt mind.
Posted: Mon Feb 13, 2012 3:49 am
by RoninZX-10R
Check out the link below, it'll give you a pretty good idea how to go about it...
viewtopic.php?f=24&t=23940&start=0&hilit=swingarm
and a few more photos from Akhara...
http://www.akhara.com/nc30/nc30rearbrakeline/index.html
Good luck
Posted: Mon Feb 13, 2012 9:52 am
by porndoguk
i drilled 2 x 20mm Dia, one in the centre just behind the shock,
the hole you drill near the hub end there is a (20mm ish dia) circular manufacturers mark from the cast mould, you need to drill central to this 10mm towards the front as if you drill directly on it youll screw up and drill into the hub/bearing holder.
Rick
Posted: Mon Feb 13, 2012 9:54 am
by porndoguk
saved me having to search
Posted: Mon Feb 13, 2012 11:59 am
by Tomzed
Thanks for the help guys
