hey guys just bought a chain and sprocket kit have come to fit it and it seems thechain adjuster is missing most of its teeth, how do i get around this? or can the adjuster be replaced?
It sounds as though the previous owner has butchered it, may need an old screwdriver or a drift and loosen it that way.
Get the replacement hub to hand before you do or the bike my be off the road til you get one, try Geoff33, I got a really mint one from him a while ago
If you take the brake disc off, you'll see a huge internal circlip that holds the hub in the swingarm. It's a bit tricky to get that off but, once you have, the whole eccentric hub should just slide out the drive side of the swingarm.
