light switch assembly,is it a simple device
is it going to be like pandoras box in there lol
having to fiddle with the switch to get the lights on so must have a lpose connection
- iDemonix
- Bike owned: '92 NC30
Re: light switch assembly,is it a simple device
NC30?
If you've not done the high beam relay mod then it could of melted inside and you'll need a new unit.
AS above.. sounds like switch is melted.leerc wrote:is it going to be like pandoras box in there lol
If you put normal H4 headlamps into the bike (60/55w) they will melt a Japanese bikes switch gear
yeah its a jap nc30, im sure they are h4 bulbs thst are in and 60/55 rings a bell i only replaced what was alreay in so have no idea if its had the relay mod done
since i bought it iv never been off high beam as low was useless and both jap and uk bike are 60w high
Are your headlights aimed properly and clean?leerc wrote:yeah its a jap nc30, im sure they are h4 bulbs thst are in and 60/55 rings a bell i only replaced what was alreay in so have no idea if its had the relay mod done
I have standard 35/60w H4R bulbs and the low-beam is fine?
i havnt checked but i think its me being used to the car HID i have in the car
- Bike owned: NSR150SP, RVF400
i had that problem.
its a simple fix, but it relapses sometimes.
you could install an external on-off switch for convenience sake!
- Bike owned: NC30, NC35
does anoyone have any pictures of this relay mod when its done?
and where i can get hold of the correct relay?
Any cheap automotive 20A relay will be fine.makz2008 wrote:does anoyone have any pictures of this relay mod when its done?
http://www.vsource.org/VFR-RVF_files/NC ... mRelay.htm
Thers some pictures here
