vfr400r valve adjust
Posted: Sun Dec 11, 2011 10:05 pm
by The Big Taveri
Hello, The my Nc30 after 13000 miles has a ticking of valves !! (rear head)
Question:I can use my bike for others 1500 miles ??'
I don't know tappet clearance, you can help me!
The Vfr400 have defect of usury cams as vfr750 f ??(cam damage)
Alessandro
Re: vfr400r valve adjust
Posted: Sun Dec 11, 2011 10:08 pm
by Davez29
Hi mate, theres a full guide to sorting this in the vfr part of the forum.
here:
viewtopic.php?f=24&t=1943
Posted: Mon Dec 12, 2011 12:01 am
by Cammo
The ticking noise is common and doesn't necessarily mean that valve clearances are out in my opinion.
There's only one way to find out though.
The nc30 doesn't suffer the same cam problems as the vf750. Actually, I don't think any other honda model was affected with the same problem.
Posted: Wed Jan 11, 2012 10:29 pm
by The Big Taveri
Thank you very much.
The next week I will control the valve clearance with oil and filter change (Motul 5100)
Alessandro
Posted: Thu Jan 12, 2012 1:47 am
by viper_biker
Slack cam chain???
Posted: Thu Jan 12, 2012 10:04 am
by porndoguk
viper_biker wrote:Slack cam chain???
NC30
Posted: Thu Jan 12, 2012 1:12 pm
porndoguk wrote:viper_biker wrote:Slack cam chain???
NC30
lol vipers was a joke
the problem with the vfr750 was the oil passage to the top end was crap design and too small.. it was easy to block and have low pressure / no oil to your cams which cause them to wear themselves away :/
Shame really, decent engine baring that (you can replace the top end lines with franken-kits' that look pretty awesome)
On topic.. follow the valve clearance guide... check them even if you don't adjust them.
You can ride it as many miles as you want until it explodes..but putting off vital checks isn't good.. many times you can get away with it damage free.. sometimes small damage occurs and other times it's major damage.
It doesn't take too long to just check the clerances.. at least if you write them down you'll have an idea how much wear is in them..
Posted: Sat Nov 18, 2023 2:30 pm
by Robert26
Hi... i have a quick two questions. Does the cam journal that is in the 'Long hole" on the cam holder actually touch the holder? How is it supported? Also, has anybody ever done anything with needle bearings on the cams?
Thanks in advance,
Robert
