CBR6Fx wheels into NC29
Posted: Fri Sep 09, 2011 9:29 pm
Hi All,
Uprating the brakes on my NC29 using NC30 lowers & calipers but also want to use pfm discs (off 893), i've been on pfm website and discs H016's won't fit either NC29 or NC30 front wheel (pfm H037),
CBR600Fx front wheel which i believe uses 120/60 17 tyre ( same as NC29 ) will accept H016 discs - i've got a mate who has an Fx so i can get the measurement across the flange where the disc bolts to (which im sure is the only measurement which will effect the offset and effect whether or not the discs line up correctly with the calipers.
but,
FX wheels are 3 spoke so i'd like to use the rear as well, which would be good as it will let me use 160 profile rear tyre.
Has anyone fitted 1 of these to an NC29, I need info on spacers and whether the caliper bracket needs machining to get it to line up with the disc.
I checked out rear wheel on my cbr600fv and there was a fair difference between it and the NC wheel
All help gtratefully accepted
SPal
but,
SPal
