Headlights dim when indicator turned on!
Posted: Fri Jun 17, 2011 10:37 pm
hi everyone,
i have a nc23 1988 which has failed it MOT for dimming dipped headlights when indicator is turned on. I have been told that it is more than likely an earthing fault, so i checked all the connections that i could find and clean them all. i have even taken out the generator, regulator/rectifier and had a look at them. i was really desperate so i started taking apart the wiring harness, but all look good. Now i am at a loose end and would really like some advice on what else to check, or maybe someone else has had the same fault and could share their knowledge with me.
