NC30 Emulstion Tubes and Needles
porndoguk
Post by porndoguk » Sat Apr 30, 2011 11:20 pm
so after taking out the washer i added to the needles, the bike is still running SHIT in the midrange between 4.5k and 6.5k miss firing/flooding
ive spoken with Rick O, who says not to remove the standard washer as its there to stop the needle rubbing the slide as with time the needle would lower its self naturally. does rick also do new emulsion tubes?
also he and a few other have suggested trying needles, and now another variable id over looked was the emulsion tubes, and the WORD ovaled was chucked into the equasion,
how do i go about measureing the emulsion tubes and needles what sizes should they be, and how far up the needle does it act for the midrange? needles i guess with a mic' but an emulsion is very small and verniers just arnt acurate enough. i want to get this sorted asap as its doing my head in.
Rick
alexwitham
Bike owned: 675R, GSXR6, NC30
Re: NC30 Emulstion Tubes and Needles
Post by alexwitham » Sat Apr 30, 2011 11:24 pm
If you need a set of emulsion tubes I'll ping some your way pal. Let me know if yours are goosed.
porndoguk
Post by porndoguk » Sat Apr 30, 2011 11:27 pm
alexwitham wrote:If you need a set of emulsion tubes I'll ping some your way pal. Let me know if yours are goosed.
you my friend are a legend
:rocks:
alexwitham
Post by alexwitham » Sat Apr 30, 2011 11:29 pm
I probably have a set of needles too if you need them.
:rocks:
porndoguk
Post by porndoguk » Sat Apr 30, 2011 11:39 pm
alexwitham wrote:I probably have a set of needles too if you need them.
:rocks:
well seeing as your being so charitable post them both over and i can just swap them and try also gonna DYNOJET 120s all round. sacking the 118 on the front, many people have suggested that i do so,
its clear from what i have learnt over the past 6months of so is no NC runs the same as an other,
how are your carbs set alex?
alexwitham
Post by alexwitham » Sat Apr 30, 2011 11:50 pm
120 dynojets, rick o needles raised 0.5mm, drilled slides, no snorkel, pipercross foam filter.
alexwitham
Can you text me next week to remind me to post them over mate, I've got a fecking shocker of a memory.
porndoguk
Post by porndoguk » Sat Apr 30, 2011 11:52 pm
alexwitham wrote:120 dynojets, rick o needles raised 0.5mm, drilled slides, no snorkel, pipercross foam filter.
hmmm,
why the no snorkel, that will reduce turbulance surely thats not a good thing on these i thought venturis and vacuums prefered turbulance to get an even mixture of A/F?
alexwitham
Post by alexwitham » Sun May 01, 2011 12:02 am
Without the snorkel it runs good at high RPM so I've left it our for track days. Long road trips etc I will put it back in.
Hadies
Post by Hadies » Sun May 01, 2011 12:54 am
I run 120 dynojets and RO needles raised 0.5mm too. I have the snorkel and standard filter though and I'm running a tad rich. No flat spots though :-)
