On the NC30, can the same shock, of the same length, be used for both a 17" & 18" rear wheel?
What modification would be needed to maintain the ride height when the 18" wheel is replaced with a 17" wheel?
I"m thinking of getting a third party rear shock. I don't want to end up having to buy another shock if I fit a 17" wheel in the future. Can the lower link be modified to make up the difference in ride height between the 18" & 17" wheels, without having to change the shock length, or is a new shock unavoidable?
Any advice from our suspension gurus gratefully received!
Shock length w. 17" & 18" rear wheel?
- tanto
- Hadies
Re: Shock length w. 17" & 18" rear wheel?
Rick Oliver does a jackup kit for the NC30 which includes a rocker and a bottom link. I think you can buy the bottom link seperately though. Its a shorter link which raises the rear a bit.
- Hadies
Just checked for you:
£85 for the full kit
£60 for the bottom link only
The shorter bottom link gives 35mm rear jack up.
I think I've also seen people drill new holes on the bottom link.
RVF lower link...
- Bike owned: NC35, 5SL, 3XV, 2MA
99 times out of 100 third-party shocks have ride height adjustment (or shock overall length if you prefer) built in.tanto wrote:I"m thinking of getting a third party rear shock.
- tanto
The ride height adjustment is 0 - 10mm, which is probably too little.Malc wrote:99 times out of 100 third-party shocks have ride height adjustment (or shock overall length if you prefer) built in.tanto wrote:I"m thinking of getting a third party rear shock.
Thanks, Hades. I had forgotten the RVF. The "dogbone", or Rick's kit, or drilling the lower link; excellent, plenty of ways to solve the problem. Given where I live, drilling a new hole and welding up the old one would probably be easiest.
Someone take my credit card. Replacement shock websites are coming up on-screen. And, they make them in Thailand...
- banoffee
got one of Rick's lower links on mine. £25 from ebay and was as new
- Bike owned: nc30
RickOliver wrote:Laying a few misconceptions to rest...
The standard shock length on an NC30/35 is 305mm, not 315mm.
315mm is the length we commonly specify for an aftermarket shock. The 10mm increase when multiplied up by the shock linkage ratio raises rear ride height by around 35mm - this improves cornering clearance and sharpens the steering to just nicely on the quick side of neutral.
If more is good, lots more is not better! A 330mm shock will give a ride height increase of around 75mm and far too much oversteer for comfort - it will make your bike very twitchy, prone to unsettling tankslappers and likely to tuck the front end and dump you in the ditch on tight bends with marginal grip (i.e. almost any `A` road roundabout in the wet...)
Rick
Yeah, but the extra 10mm isn't 10mm and that's it. There is a multiplying factor involved also, somewhere in the region of 3.5 on the VFR/RVF, so full extra 10mm is about 35mm on the ride height.tanto wrote:The ride height adjustment is 0 - 10mm, which is probably too little.Malc wrote:99 times out of 100 third-party shocks have ride height adjustment (or shock overall length if you prefer) built in.tanto wrote:I"m thinking of getting a third party rear shock.
EDIT - see Rick has been quoted explaining the same! Great minds, etc...
