Front brake caliper pistons won't retract
- Man_Named_Dave
- Bike owned: NC30(K)
I just tried to re-fit my (NC 30) front brake pads. The left-hand ones went on ok, but on the right-hand caliper the pistons are pushed right up against the brake pad. The Haynes manual says to use your hands or some wood to push them back in, but they're not budging at all. Do I need to open up the whole blasted caliper or drain off some fluid?
- mattUKNC
Re: Front brake caliper pistons won't retract
Hmm, is that with the brake res cap off?!
I have a caliper splitter tool (to hold the pistons apart), but you'd still need to open it up enough to get the tool in. (As it were)
- Man_Named_Dave
I haven't touched it.mattUKNC wrote:Hmm, is that with the brake res cap off?!I have a caliper splitter tool (to hold the pistons apart), but you'd still need to open it up enough to get the tool in. (As it were)
- Bike owned: RVF400 NC35
take the res lid off, just make sure when you push the piston back the level doesnt spill over the top...
if your replacing the pads, use one of the old pads and use a lever against the pad to push the piston back in.. it makes no difference if your digging and wrecking the old pad.. i used a large spanner as a lever..
if you need to drain off some fluid, use a syringe and take from the res...
- Man_Named_Dave
I gave that a try, Hardnut, but no joy. The pistons squeeze a little but don't retract.
As for the res, the level is actually right on the bottom of the lower line.
- mattUKNC
That will rise as the pistons go back to where they should be.Man_Named_Dave wrote:I gave that a try, Hardnut, but no joy. The pistons squeeze a little but don't retract.
Have you got a long screwdriver to get in there?
- Man_Named_Dave
There isn't even half a mm between the pad and pistons. I can't get a flathead in there at all.mattUKNC wrote:That will rise as the pistons go back to where they should be.
- mattUKNC
Hmm, you're quite close to me aren't you? PM your address and I'll see if I can get over there.Man_Named_Dave wrote:There isn't even half a mm between the pad and pistons. I can't get a flathead in there at all.mattUKNC wrote:That will rise as the pistons go back to where they should be.
(I'll bring the 'big' hammer.)
can you undo the pad retaining pin and little retainer plug, remove the pads and then use one old pad against the pistons with a lever to push it back in?
with the pin removed you might be able to rpise one pad out?
- Bike owned: NC35
that's some crazy pressure you have there. out of curiosity, u didn't by any chance squeeze the brake lever when you put the 1st side back on? stupid question i know but it can happen
