faulty cdi unit?
leethedaddy
Bike owned: cbr 400 aero
faulty cdi unit?
Post by leethedaddy » Thu Feb 17, 2011 7:21 pm
Hi all ;) i have a cbr 400 aero 1986 model... i suspect a faulty cdi unit, does any one know where i can get it checked or repaired? or where i can buy a new 1? many thanks lee :grin:
thunderace
Bike owned: R6, YZF600R
Re: faulty cdi unit?
Post by thunderace » Thu Feb 17, 2011 8:34 pm
I'd just scour the net for a used one. If you're desperate for a brand new one, try DSS. It won't be cheap though.
hannakournikova
Bike owned: NC30, NC35 & SP2
faulty cdi unit?
Post by hannakournikova » Thu Feb 17, 2011 9:47 pm
What are the faults that make you think cdi?
leethedaddy
Post by leethedaddy » Thu Feb 17, 2011 9:54 pm
theres no spark at th plugs...
sh4d0w0lf
Bike owned: VFR400R NC24, GPZ600R
Post by sh4d0w0lf » Fri Feb 18, 2011 10:03 am
You'd be better off posting this in the CBR section.. however have you checked your HT Leads, Coils and wiring back to the CDI unit.. no spark doesn't necisarily (soz bout the spelling) mean that the CDI is to blame.
Hope that helps,
Adam.
Please don't flame me if this has been reposted in the correct section.. I have not looked. :ban:
Post by Evilchicken0 » Fri Feb 18, 2011 10:22 am
To be honest the CDI is probably the last thing to go.
Check the battery isn't low.
Renew the plugs.
Check all the plugs for a spark - which is easier at night.
If it's one plug then it could be the plug cap or ht lead. Unscrew the cap cut 1/2 cm off the lead and screw it back in.
If it's two plugs then it coul be a coil, check the wires going to that coil, take them off clean then and make sure they're tight when you put them on again.
If it's all four then have a look at the crank sender (on the right of the engine) trace the wires through to the loom and clean the connector, check the wires on each side of the connector are the same colours too.
Mitch
Bike owned: 1987 cbr 400 aero rg
Post by Mitch » Thu Mar 17, 2011 9:31 pm
Hi lee, hope you have sorted your cdi prob out but if not may i suggest checking the regulator rectifier. my aero kept giving me grief until one day the battery boiled. when i put a new one on the cdi started smoking. See my previous post history. i was advised to check the reg. rect. coz the cdi is quite an expensive piece to get, if u can get one. I replaced the reg. rect. and hey presto. Sweet as a nut and the cdi was ok. Running better than ever and not too expensive either. Good luck-----Mitch
