Fitting CBR600RR Forks to my NC30
Causon67
Post by Causon67 » Fri Jan 28, 2011 12:34 am
Hi, im new to all this im 18 and I bought an NC30 and was wondering if you could help to tell me what I would need to do to fit CBR600 forks to my bike
Thanks Pete
skinnydog0_0
Bike owned: Penny Farthing
Re: Fitting CBR600RR Forks to my NC30
Post by skinnydog0_0 » Fri Jan 28, 2011 6:44 pm
Is there a reason why you want to change the forks?
Are yours fecked?
If it's just an upgrade you are after, i reckcon teh Rick Oliver fork kit would be a far simpler and cheaper option ;)
Causon67
Post by Causon67 » Fri Jan 28, 2011 7:14 pm
Well Im finking of putting it on the track, but still using on the road too.
Its mainly just for any upgrade and i would like the usd forks that are fully adjustable. :grin:
skinnydog0_0
Post by skinnydog0_0 » Fri Jan 28, 2011 7:27 pm
What riding/track experience do you have?
If you have the time and the money to do the upgrade then thats great, but i think you would be better spending your cash on the Rick O upgrade, some sticky rubber, and a few trackdays. You will find it hard to outride the forks on an NC30 (once they have been sorted) also look at getting a rear shock sorted Upgrade/refresh :peace:
Causon67
Post by Causon67 » Fri Jan 28, 2011 7:46 pm
You must be thinking im useless at the minute, but hey im an apprentice as a mechinal so the techenical side will come in time.
Another question where do i get this
skinnydog0_0
Post by skinnydog0_0 » Fri Jan 28, 2011 8:04 pm
Causon67 wrote:You must be thinking im useless at the minute, but hey im an apprentice as a mechinal so the techenical side will come in time.
Another question where do i get this. Where do you get what?
No dont think you are useless at all, but i dont want to teach you to suck eggs either :grin: I guess it all comes down to what you want to achieve, and how much you want to spend.
Is the bike going to be used mainly on the road or track?
Drunken Munkey has done the cbr600rr fork mod so would be able to let you in on any pitfalls and the benefits of it.
Getting stuck in with the spanners is a sure way to find out how the bike works and will teach you loads about it. :peace:
Post by Drunkn Munky » Fri Jan 28, 2011 8:19 pm
Not done the conversion yet mate but its pretty straight forward. your need the whole front end and 05,06 yokes suit the NC offset better than the 07 onwards yokes. I can dig out the details ive been sent for you if you want.
Causon67
Post by Causon67 » Fri Jan 28, 2011 8:31 pm
Well both really, I use it as a road bike and i do about 2 or 3 trackdays a month :grin:
Causon67
Post by Causon67 » Fri Jan 28, 2011 8:32 pm
If its possible to have the details that would be really nice thanks 8-)
slowsport
Bike owned: NC35
Post by slowsport » Fri Jan 28, 2011 8:37 pm
i also would recomend the Rick O fork upgrade as this is the route i will be taking with my nc35, even though on previous bikes i done the conversion
if you really want the usd fork conversion you are going to have to press out your stem from the nc30 (get a hydraulic press to push downwards) and press this into the bottom yoke of the cbr600rr if the stem is loose get it welded in as it shouldn't really move. then you can use your stem and head bearings on your frame with the cbr600rr triple trees. also if you dont have the cbr600rr wheel and spacers you will have to use the cbr600rr wheel axle and try and correctly space your wheel on. the other things that also may need to be modified is bolts or sturdy metal welded into the bottom yoke for steering stops ( if the ones on the cbr yokes aren't the same as your bike) and you may need a spacer for the top yoke to fit tightly as your stem may be thinner in width to the cbr600rr stem.
i hope that is clear as that is the usual route to do fork conversions, but for the trouble and the little gains you get the rick oliver kit will be easier money wise and mechanical wise. and most wouldnt notice the difference to a well suited kit if it is spec'd to your weight.
