will not start
will not start
hi after some friendly advise if anyone can help my 1988 nc23 has been playing up,,,it will not strt unless i bump it,,or try to several times which is normally followed by a backfire from the exhaust ,,the engine sounds like its turning over lovely but wont seem to fire. If it stalls after running the problem still pursist,,,ii have changed the red reck and charged the battery any clues would be good thanks
Re: will not start
you say you charged the battery, but is it ok or knackered, i had the same problem on my last 88 nc23, it was the reg/rec..just a thought..ted
Re: will not start
yeh battery charged and the red reck seems fine,,,putting new plugs in tomorrow hopefully but is getting frustrating
- hallsie
- Bike owned: NC29
will not start
Mine did this many times and it was a dirty neutral switch connection
Re: will not start
i iwill try anything am struggling,,,where would that switch be please
- Davez29
- Bike owned: NC29 forever
Re: will not start
Its bottom left, on the engine sump near the sidestand switch, be aware oil wil come flooding out if you remove it, so stick a big enough dish under to catch the oil, be quick cleaning it or have a small bolt ready to stem the flow. Prepare to add more oil as needed after you put the switch back. It should spring in and out without any crap stopping it.ade100481 wrote:i iwill try anything am struggling,,,where would that switch be please
Re: will not start
If you can't find the sidestand switch, don't worry too much.....there isn't one!
- Davez29
Re: will not start
yep, i meant to say sidestand but my fingers added the switch bit!Wozza wrote:If you can't find the sidestand switch, don't worry too much.....there isn't one!
Re: will not start
I'm just being a pedantic nuisance, ignore me
