removing corossion from engine?
Newflee
Post by Newflee » Sat Oct 16, 2010 4:58 am
I need some advice on removing the corrosion/ oxidation from my RVF engine. It is an import from Japan and has the usual (so I'm told) surface corrosion in the engine block/heads and carbs. It will not wash off to my satisfaction however it has no impact other than that I know it's under the fairings. \i can remove it mechanically with wire brush but wonder if there is any product or procedure to remove it chemically with engine and accessories left on the frame....the easy way.
I'm thinking that there is no easy way but let me know .
Thanks,
Lee
ibby4585
Bike owned: SP's
Re: removing corossion from engine?
Post by ibby4585 » Sat Oct 16, 2010 8:22 am
I use gunk in a cheapy spray can and use a stiff brush, on harder spots I use a brass wire brush.
It's hard work and messy but does get it clean.
I then use motorex shine and polish
Gives it a sheen
Kris
fixer
Bike owned: nc30/bsab25
Post by fixer » Sun Oct 17, 2010 10:05 am
Stiff brush and paraffin and elbow grease. :grin: :plus:
F I X E R
uber pikey
Bike owned: NC30, GS700e GSX750 katana pop
Post by uber pikey » Sun Oct 17, 2010 10:26 am
doesn't Genolite work?
Post by Neosophist » Sun Oct 17, 2010 11:54 am
If you keep the bike outside or somewhere damp its going to happen again anyway, probably a job best saved for when the engine is out.. you can polish up all the corroded bits and either pain them or laquer them.
