Page 1 of 2
rvf carb service
Posted: Sat Oct 02, 2010 11:14 am
by code2006
hi guys i just changed my jets on my rvf and now i want to drill the slides useing a 2.5mm drill and put an extra washer 0.5mm on the needle but i can't figure it out how to take the needle off the slide
also i read somewere that its not recommended to drill the slides ?
also im following cammos diy guide and im not sure if i should adjust the pilot to two and a quarter turns out or 1 and 5/8th i think
my rvf is standard except i have a tyga carbon twin can full exhaust system
thanks alex
Re: rvf carb service
Posted: Sat Oct 02, 2010 11:52 am
Well..
Don't do it. The drilling etc is for NC30 carbs only.
Stop fiddling dude... :o
Posted: Sat Oct 02, 2010 12:06 pm
by code2006
CMSMJ1 wrote:Well..
lol ok
how about the washer and pilot jet?
thanks
Posted: Sat Oct 02, 2010 12:29 pm
by ibby4585
code2006 wrote:
CMSMJ1 wrote:Well..
lol ok
thanks
Step away from the workbench!!
Posted: Sat Oct 02, 2010 12:52 pm
by code2006
ibby4585 wrote:
code2006 wrote:
CMSMJ1 wrote:Well..
lol ok
thanks
ok hmm what to do next lol
all i have left to do is my carbs and indicators lol
i think im gona make a cup of tea then start on my indicators till someone can correct me lol
Posted: Sat Oct 02, 2010 1:56 pm
code2006 wrote:
CMSMJ1 wrote:Well..
lol ok
thanks
Dyno it...see if it nees anything 8-)
Posted: Sat Oct 02, 2010 2:06 pm
by code2006
CMSMJ1 wrote:
code2006 wrote:
CMSMJ1 wrote:Well..
lol ok
thanks
yer will do that later on lol
for now i will leave the washer and set the pilot jet screw to 1 and 5/8 turns out
thanks
ps i know i dont need to change pilot jet it was the screw i was on about, just didnt know how many turns i had to do on the rvf carbs for std bike with tyga exhuast
Posted: Sat Oct 02, 2010 2:53 pm
by Drunkn Munky
:lol: For what its worth ive always found a extra 0.5mm washer and hrc slide springs work a treat on rvf carbs to sort out the midrange on engines with standard tune.
Posted: Sat Oct 02, 2010 3:02 pm
by code2006
Drunkn Munky wrote::lol: For what its worth ive always found a extra 0.5mm washer and hrc slide springs work a treat on rvf carbs to sort out the midrange on engines with standard tune.
well thats wot i thought but i couldnt figure out how to take the needle off the slider to put an extra washer
just re fitted the carbs and pannels and i forgot to turn the screw under the carbs that emptys the petrol out so i have to take the carbs off the bike again :x :x
will take the carbs off 2moro but it would be nice if there was some info about removing the needle
on the nc30 carbs theres a screw but i dont think there was a screw on mine :?
Posted: Sat Oct 02, 2010 3:07 pm
by Drunkn Munky
IIRC you remove the needle the same way as you do 30 carbs, philips screw driver inside the slide then twist. Im sure theres pics in the haynes manual. I always go up a jet size too if using a can or system. DONT drill the slides. 30 & 35 carbs are different beasts and using the 30 guide to mod your 35 carbs is going to end in tears.
