Quick question regarding the rear wheel: do you need to use a new split pin each time? And where can I get one? (I want to get this done next week and would prefer not to have to wait weeks for it to come from overseas..
I've also read that raising the height of the rear of the bike makes a massive difference in handling on these bikes.
I have placed a bid on this item, but not quite sure how to install the shim...
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... K:MEWAX:IT
I've just looked in the Haynes manual at the section which tells you how to remove the rear shock and it's just confused me even more.. Will I be able to unscrew the shock with the exhaust in place, or will I only need to remove the rear seat cowling and the RHS rearset? (What am I even unscrewing? Am I unscrewing the shock, or the top shock bolt?) Is it easy to access and will I need any special tools to access whatever it is I need to undo?
I have a SS swingarm stand but how do I support the frame? Can I just stick some wood under the rear tyre to support it?
Also, do I need to take note of any settings before I unscrew the shock/shock bolt so I can do it up the same?
Sorry about all the noob questions. I'm still new to bikes so trying to get my head around all this.. but I'm eager to learn and I'll give anything a go!
