Rvf 400 throttle cables
code2006
Post by code2006 » Fri Aug 27, 2010 11:49 am
Ok I have changed my throttle cables but I can't remember which root the cables went.
I have fitted them the way I thought they went but when I pull the throttle back it does not got back fast it's very slow to go back to no throttle. Any ideas ?
Thanks Alex
Re: Rvf 400 throttle cables
Post by Drunkn Munky » Fri Aug 27, 2010 12:43 pm
try loosening the throttle housing bolts a smidge if your sure you have the right route. I do have some pics of the cable run but there on another laptop.
code2006
Post by code2006 » Fri Aug 27, 2010 1:52 pm
Drunkn Munky wrote:try loosening the throttle housing bolts a smidge if your sure you have the right route. I do have some pics of the cable run but there on another laptop.
Well tbh I'm not sure as there is more than one root they can go but if u could try and upload them pics I would be brilliant
code2006
Post by code2006 » Sun Aug 29, 2010 5:51 am
Bump
skinnydog0_0
Bike owned: Penny Farthing
Post by skinnydog0_0 » Sun Aug 29, 2010 9:02 pm
On my 35, i run round the front of the right fork leg, under the clock bracket, then over the top of the upper rad on the left hand side as you look down at it. then under the wiring bunch, and to the carbs. Bear in mind i have an ex race rad with the cut out for ram air, but i think that you should be able to fit through that route with standard rad. ;)
Also as DM said, try loosening the cable adjuster nuts, i have found that even half a turn in either direction can cause them to stick.
code2006
Post by code2006 » Mon Aug 30, 2010 12:18 am
skinnydog0_0 wrote:On my 35, i run round the front of the right fork leg, under the clock bracket, then over the top of the upper rad on the left hand side as you look down at it. then under the wiring bunch, and to the carbs. Bear in mind i have an ex race rad with the cut out for ram air, but i think that you should be able to fit through that route with standard rad. ;)
Sweet mate thanks
I want to get this small prob sorted as I got new fairings going on the bike :)
As for the adjuster nuts is that on the carbs or throttle body?
Throttle body they r lose as I just fitted new cables and i didn't tighten them up
Thanks Alex
skinnydog0_0
Post by skinnydog0_0 » Mon Aug 30, 2010 10:32 am
The adjuster nut's at the carb end. ;)
code2006
Post by code2006 » Tue Aug 31, 2010 8:04 pm
Thanks for this
Done mine like u have yours and it's now perfect
skinnydog0_0
Post by skinnydog0_0 » Tue Aug 31, 2010 8:35 pm
No problem, now go stretch those throttle cables ;)
code2006
Post by code2006 » Tue Aug 31, 2010 8:41 pm
skinnydog0_0 wrote:No problem, now go stretch those throttle cables ;)
Not just yet :(
Still got to put my new fairings back on, wait for my new jets to come and sort out my indicators and back lights
For some odd reason they r now not working . Will try and sort most of it 2moro
