Why the hell my NC30 won`t start again
theoutsider
Post by theoutsider » Mon Aug 16, 2010 5:50 pm
Right I bought my bike about a year ago,haven`t ridden it yet,but I started the bike weekly to make sure it starts and to hear the v4 growl,about 3 months ago it would not start,(i fitted the restrictors for some reason)changed the plugs it fired straight away,I noticed the rectifier plugs are melted and the reg/rec is smokey if revved over 10k,from about a month ago the bike would start straight away,run for few minutes until the rec/reg would get warm/hot,today tried to start the bike,it started but died the next second,after that it felt like it was trying to start but it didn`t,and now it just turns over.
The plugs are brand new,have very strong spark,there is compression and there is fuel.
Could it be the fu**ed reg/rec,and also could this be the reason the bike wouldn`t rev properly?
I`m gutted,please can anyone point me in the right direction?
Any suggestions will be really helpful.
Thank you
Regards Eddie
code2006
Post by code2006 » Mon Aug 16, 2010 5:57 pm
Do u know if there is fuel getting to the engine?
Maybe your carbs need cleaning
theoutsider
Re: Why the hell my NC30 won`t start again
Post by theoutsider » Mon Aug 16, 2010 6:50 pm
fuel is getting there 100% the I can smell the petrol if I try to start the bike
Post by Neosophist » Mon Aug 16, 2010 8:01 pm
If you can smell petrol sounds like you've flooded the engine.
It's not going to run right with a broken reg/rec anyway so you need to do a full test of the electrical system and diagnose genny / battery / reg-rec and replace as appropriate.
How are you trying to start it? Should be using full choke no throttle at all until its running...
Post by Drunkn Munky » Mon Aug 16, 2010 8:41 pm
Get the reg/rec changed first, also not sure how true this is but ive heard its not a good idea to start these bikes and and leave them to idle time and time again without riding it. Ive had engines out for months on end and not once had trouble getting them going again.
theoutsider
Post by theoutsider » Mon Aug 16, 2010 8:47 pm
Tried to start it with full choke and no throttle,I only start the bike for about 5 minutes rev it a bit let it settle and stop it
skinnydog0_0
Bike owned: Penny Farthing
Post by skinnydog0_0 » Mon Aug 16, 2010 10:21 pm
If the Reg/rec is fecked then you have probably blown your main fuse too (30A) at the starter relay.
Neosophist wrote:If you can smell petrol sounds like you've flooded the engine.
:plus:
I try full choke till it catches, then half choke as soon as it starts, leave it for a min, then turn the choke off and gently rev it.
theoutsider
Post by theoutsider » Tue Aug 17, 2010 6:32 pm
The main fuse is fine,carbs are clean,but now it doesn`t even try to start,it just turns over,tried everything except changing the reg/rec because I have no funds,but it should start though with it broken?
There is fuel,there is compression(loads),and there is spark?What the hell is missing?
skinnydog0_0
Post by skinnydog0_0 » Tue Aug 17, 2010 6:35 pm
Is the bike a 30 or 35. does it have the right cdi?
theoutsider
Post by theoutsider » Tue Aug 17, 2010 6:40 pm
It`s a 30,with the right cdi,the bike ran like a dream,nothing has been replaced
