mounting Shock reservoir
nakes999
Post by nakes999 » Mon Jul 26, 2010 5:58 pm
I recently fitted a NC30 shock to my NC35... I mounted the reservoir to the back of the right side pillion footrest hanger but the wheel seems to be scraping up against it...
Any idea where or how else I can mount this?
ibby4585
Bike owned: SP's
Re: mounting Shock reservoir
Post by ibby4585 » Mon Jul 26, 2010 8:26 pm
Whats wrong with the standard mounting?? small bracket thats uses the same bolts that the rear pillion pegs use??
Kris
Post by Neosophist » Mon Jul 26, 2010 8:29 pm
Why did you fit the 30 shock?
Some of the linkeage / dogbone / bushes are different between the 30 / 35 so is the shock actually and different?
And as for mounting the remote resevoir, i'd say anywhere where the wheel can't hit it :grin:
Post by Neosophist » Mon Jul 26, 2010 8:30 pm
ibby4585 wrote:Whats wrong with the standard mounting?? small bracket thats uses the same bolts that the rear pillion pegs use??
Kris
The NC35 doesn't have a remote resevoir on the standard shock.
nakes999
Post by nakes999 » Mon Jul 26, 2010 8:53 pm
Neosophist wrote:Why did you fit the 30 shock?
I fitted the NC30 shock because it was the cheapest option at the time. Also the guy I bought it from said it was rebuilt for a track bike so I figured at half the price of a rebuilt std NC30 shock from a bike shop, this was a better buy... the guy also had a std NC35 shock but I went with the rebuilt 30 shock instead because some people on here rate it better than the NC35 unit.. mostly because it can be rebuilt and the 35 can't be?(eventhough a local suspension specialist said Any shock can be rebuilt)
The shock went in no problem.. I've been told by a few people that the NC30 and NC35 shock is interchangeable... There does seem to be a small amount of ride height increase... I'm not sure if that has anything to do with it being an NC30 shock or that it's been "extensively rebuilt" (according to the previous owner)
Either way, it was cheap enough as I just needed something that wasn't leaking oil all over.. and I have noticed in improvement in the rear end...
HAHA.. yes that's exactly what I was thinking.. "somewhere where it doesn't hit the wheel.. So I guess I need a bracket so that it mounts a bit more out of the way then... I just thought maybe someone had a slightly more hidden spot to mount it...
my original post with a pic of the shock:
viewtopic.php?f=22&t=19512
Dynamohum
Post by Dynamohum » Mon Jul 26, 2010 11:43 pm
has bike ever been dropped on r/h side at some time in the past subframe twisted
maybe at pillion peg mounting point :?:
ibby4585
Bike owned: SP's
Post by ibby4585 » Mon Jul 26, 2010 11:46 pm
Kris
No i meant the standard NC30 mount!! im sure it fits on the rvf subframe!!
Kris
superlite
Bike owned: TLS, LB80 x 2
Post by superlite » Tue Jul 27, 2010 8:53 am
ibby4585 wrote:No i meant the standard NC30 mount!! im sure it fits on the rvf subframe!!
:plus: Should be able to pick up a bracket on here for next to nothing.
'Take it to the Back'
ibby4585
Bike owned: SP's
Post by ibby4585 » Tue Jul 27, 2010 9:53 am
Geoff33 will have a few!
nakes999
Post by nakes999 » Tue Jul 27, 2010 11:31 am
davethetrucker wrote:has bike ever been dropped on r/h side at some time in the past subframe twisted
The bike has been dropped but nothing's bent or twisted...
