I'm new to the site and would rele appreciate help/tips/advice...
I've just un-earthed my NC21/24 project from the back of the garage. Its an NC21 (circa 1986) with the NC24 swing arm conversion.
In trusty V4 style, i've changed the oil, given the plugs a quick clean added some fuel and instantly shes popping and smoking - however not running correctly. I'm a college trained plant mechanic so not a total numtpy with the basics. The carbs are gonna come off thorough clean out of float chambers and jets etc. Will stick some new plugs in her. I'm also going to change fuel and vacuum pipes from the tap etc.
The bike was bought as a project and has never run properly and I'm not familiar with any common issues/hiccups these bikes have.
My questions for you the experts are: once the carbs are cleaned is there anything that requires specifically setting; float heights, choke plungers etc? Also is there any other common items of TLC these bikes need after being stood up for a while?
My main objective is to ensure she runs sweet and correctly before I commence the stripdown and rebuilding her back to all her glory.
Looking forward to your comments
Dave
