Valve Clearance Guide
deequeue
Reactions:
Bike owned: MV F4 750, NC30, ZX6R, R6 5eb
Re: Valve Clearance Guide
Post by deequeue » Thu Jan 31, 2013 12:26 pm
Hi Speedy,
After doing this the other week, there was a little oil, but not half a gallon, by any stretch. A rag under the lower end of the timing cover catches it all - its maybe 20 or 30 ml of oil in front and rear.
speedy231278
Reactions:
Post by speedy231278 » Thu Jan 31, 2013 12:29 pm
I'll probably do the oil at the same time anyway, so it's probably irrelevant. I was just bloody annoyed when I pulled the water pump out expecting a trickle or dribble, and got a full-on torrent! lol
deequeue
Reactions:
Post by deequeue » Thu Jan 31, 2013 12:36 pm
You'll still get some up there - it pools in the lowest corner of the V's when its on the sidestand - did this on my NC21 as well when I was checking the shims.
Best bit is when you forget you have taken the cover off and find a couple of random drips of oil on the floor "Where the F* did that... ohhh yeah!"
Reactions:
Bike owned: ZXR400 / VFR400
Post by Neosophist » Sat Feb 02, 2013 1:34 pm
speedy231278 wrote:I'll probably do the oil at the same time anyway, so it's probably irrelevant. I was just bloody annoyed when I pulled the water pump out expecting a trickle or dribble, and got a full-on torrent! lol
The water pump goes directly into the engine, youll get most of the oil come out if you remove it without draining the oil.
I dont have the haynes book to hand but surely it doesnt say remove the water pump with the engine oil in the bike.
The generator cover yes, but the waterpump?
speedy231278
Reactions:
Post by speedy231278 » Sun Feb 10, 2013 11:06 pm
Neosophist wrote:I dont have the haynes book to hand but surely it doesnt say remove the water pump with the engine oil in the bike.
Nope, water pump! I believe the wording is 'some residual oil may be present'. I can only assume that I glanced at the section that states how to remove the water pump while taking the engine apart, in which case there will be a previous instruction to drop the oil first. Regardless, the lesson was learned! lol
Reactions:
Post by Neosophist » Mon Feb 11, 2013 5:21 am
Aha yes,
If you lay the bike almost on its side so the oil is in the clutch section of the bike you can get the pump out but otherwise drop the oil else you will have a sea of oil going on, as you seem to have found out!
Jac-al
Reactions:
Post by Jac-al » Sun Jun 02, 2013 3:16 pm
Busy with valve clearances, most seem to be the right gaps but 2 or 3 are 0.02/0.03mm out, should i still change them or will it be ok?
gavins
Reactions:
Bike owned: NC30, ER6f, K5 750
Post by gavins » Mon Jun 03, 2013 4:09 pm
If they're out of the range of acceptable clearance then change them. It would be daft not to for the effort of pushing a rocker arm over and changing a £2.50 shim.
They'll be tight rather than too loose (unless they've been maladjusted previously) and worst case you can burn out a valve or have valve/piston interface.
Jac-al
Reactions:
Post by Jac-al » Mon Jun 03, 2013 4:13 pm
I left them as is cause they were too loose and will probably tighten up and couldnt get them out
porndoguk
Reactions:
Post by porndoguk » Mon Jun 03, 2013 7:18 pm
Jac-al wrote:I left them as is cause they were too loose and will probably tighten up and couldnt get them out
they will be loose probally because of carbon build up around the valve stems from poor jetting etc,
youd be better to investigate than leave as is because your only going to get the engine running worse, and if the valves are open slightly they you run the risk of smacking into the crown in time.
Hondas tollerances are tight for a reason,
What size shims are currently in the out of tolerance valves?
