Hi i just dropped the oil out of my mates NC35, it was a dark brown color, not really milky or anything, but there is a strong smell of fuel in the oil.
Is this normal?
The bike has been playing up and apparently won't start, I'm giving it a once over before anything.
Fuel in Oil?
- Jon
Re: Fuel in Oil?
Hi
If people play with the fuel tap doing a HRC mod (bypassing the vacuum shut off) they have a habit of dumping fuel into the sump, normaly a fair bit though.
Was the oil level a fair bit over full?
regards
jon
regards
jon
Re: Fuel in Oil?
The level was pretty much spot on, I have changed it all now anyways, so I will check it after the first ride and see how it looks.
Thanks for your help,
callboy
callboy
Re: Fuel in Oil?
So no one thinks this could be a blow by problem?
- skinnydog0_0
- Bike owned: Penny Farthing
Re: Fuel in Oil?
Have you checked to see if the fuel tap is leaking?
Re: Fuel in Oil?
Blow-by would be super-heated exhaust gas, not neat liquid petrol.
It could be the carbs leaking petrol into the cylinders when the bike isnt moving as the valves are leaking.
